- Replies 18
- Views 2.4k
Mopar1973Man 5 posts
Leaky88 5 posts
24Vdodge 2 posts
Me78569 2 posts
You might want to look into a headlight relay harness that draws the headlight current from your battery’s and not the switch, although the trailer wiring has its own relay and fuses it should not eff
Depends on how it's wired and what kind of lights you are using. Like my HID headlights are half of the power draw at a 35w now. Then the driving likes are a mere 18w now compared to the four 100w spo
you can do it right for ~50% of the prebuilt cost, but I wont lie, it is a lot of work.
Hi,
My owners manual states:
”Adding lights or electrical devices to the headlamp/park lamp circuit without a separate relay can damage the headlamp switch and wire harness.”
Further and more specific to my 3500, it states: “All Ram pickup models with cab clearance lights or any 3500 models must add a relay to the circuit before drawing any current from the headlamp switch.”
I am going to be hauling a Gooseneck and I’m wanting to know if anyone has a relay for the additional lighting on their trailer.
Thanks Leaky
