Abs light comes on and have codes for right front open, right front short and no signal on right front as well as rom code and time out codes
  • Replies 7
  • Views 1.9k
  • kzimmer
    kzimmer
    Just don't feed them after midnight.
  • Mopar1973Man
    Replace the sensors as a pair.   Retest.    If it's still there then replace the bearings as a pair. If one bearing is bad the other is close by to failure.
  • dripley
    dripley
    Gremlins, everybody has them.
Retest.
I put new wheel bearings and still one sensor is dropping out, does it after driving a while never when cold.
My driver side bearing went at about 200k passenger side at 280ish.
My brake booster went out, abs light came on then
