Oil Pressure Running High
- Replies 62
- Views 17k
leety 17 posts
Mopar1973Man 15 posts
AH64ID 10 posts
dripley 8 posts
this is the sensor I put in my 98.5 $16 prime and worked fine I paid over $100 for the previous one. https://www.amazon.com/gp/product/B01A0RH8O8/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&
You might ought to look at your sensor harness and be sure it is a 3 wire sensor. The 02's have a one wire switch. Just not sure whether Dodge made the change on the late 01's or the early 02's. Mine
I was going to suggest changing a filter, just never know. What filter are you using currently?
Hi All, my truck has recently presented a new issue. The oil pressure reads rather high, mostly all the time on the gauge on the dash.
I'm thinking the oil pressure sensor could be failing, but I would rather make sure my oil pressure is correct.
The bad news is I'm about 200 miles away from home for the next week and don't have my service manual with me (doh!).
The good news is I have access to tools so I may be able to solve this while I'm here.
I have a mechanical oil pressure gauge and was thinking about testing the pressure first before making assumptions, does anyone know if anyone posted an article about how to properly run the mechanical oil pressure test on my 2001 5.9?
Also if it is the sensor does anyone have any thoughts on the best replacement part to get with? Are there any good lower price aftermarket units or...?
Thanks in advance for the help.
