Driveabilty issues and codes p0216 and p0382
- Replies 12
- Views 4.8k
Mopar1973Man 3 posts
dripley 2 posts
Royal Squire 2 posts
Tractorman 2 posts
On my recent trip ran into problems that caused me to turn around and head home
Very low power and limped it from Indianapolis to missouri got within 40 miles and died out no restart. Found lift pump hardly pushing any fuel. Got towed to house and investigated.
Found in tank fuel pump screen plugged
Cleaned and retested- still poor
Put another in tank pump and filter. don't have $ for better system at this time
My pressure gauge won't read cheap hf kit
But definate improvement in flow and pressure
No lite on dash
But scanner came up with p1689. P0216 and p0382
Did the W-T ground mod and the p1689 went away
Still have low power
Seems to run better when cold
Starts fine idles smooth. Doesn't miss or skip
Found bad connection between batteries- was only starting on drivers battery- fixed
Starting to think ecm may be problem
