Eliminating Lift pump power
- Replies 9
- Views 2.9k
dripley 2 posts
Dieselfuture 2 posts
Me78569 1 post
hdpwipmonkey 1 post
Popular Days
1688 is the PSG on the VP44 is fried. This is caused by excessive AC noise which is bad alternator and poor ground issues. W-T ground wire mod will fix this from happening again.
most lift pumps are powered through a relay that is triggered using the stock power plug. This does not trigger a code and also makes sure the aftermarket pump acts like the stock program intended.
What model fass, how did you hook it up. 2 power wires for motor go to battery and a plug, plugs close to ecm area.
I installed a Fass Fuel pump & water seperation system & in the instructions it simply says unplug the power for the stock lift pump. Well needless to say that equals codes & Fass tech support had 2 suggestions.
1. leave it uplugged & if the code bothers you some code readers will erase that code from the system. Umm no.
2. If you go to an auto parts store you can by a resistor, "I believe it's 5 ohm & plug the power line into that & it simply tricks the ECM into thinking that it is plugged in and working fine. (hmm sounds like a guess, guessing I can do on my own thx)
So anybody have a better idea?
I'm actually getting 3 codes & it almost started twice, but I refuse to do long cranks. I have fuel up to the injectors already I started with 1,3,5 lines being loose.
P1693 JTEC detected companion?, P1688 Internal Inj. pump controller failure, P0238 (I think) transfer pump curcuit out of range.
Going to finish reviewing all my installs check it again after clearing codes & trying to fire it again.
Thank you all. !
P.S. The instructions on this Fass System leave a lot to be desired I mean WOW. Another time I will elaborate.
