Track Bar Keeps Coming Loose
- Replies 17
- Views 8.2k
TheGreatWhite 6 posts
Evan 4 posts
Mopar1973Man 2 posts
dripley 2 posts
You can't adjust it parrel. Nor can a alignment. It is what it is. I think the drag is actually at a slightly steeper angle then the track bar with the 4th gen steering. Slightly slightly I d
I believe they sell kids to retrofit an adjustable track bar to our second to our 2nd gens. I made my own bracket on the frame and modified my track bar tha to be adjustable with poly bushing in
Here's mine
Back in October I went ahead and upgraded to the 4th gen tie rods and while I was at it I replaced the track bar, and everything was all peachy until I hit a bump and it dropped out the socket on the driver side and I could never get it to stay, so I returned it and got a Moog bar and I'm still having problems, in fact, it's worse with bump-steer and it's like driving a wet noodle down the road. If torqued them to spec, loctited them, and even stripped the nut on the frame side I tightened it so much, and here I still sit. If anyone has a solution, it would be much appreciated! Thanks!
