Starts fine, runs strong, then stalls. restart only after fuel overflow valve reset
- Replies 22
- Views 6.4k
Scuba64 7 posts
Mopar1973Man 5 posts
dripley 3 posts
Haggar 2 posts
He'll need to key off for 10 seconds. Then do the starter bump. Then it will run the 20 seconds. The stall will be counted and key bump will not function. The ECM has to be down for 10 seconds and do
Mine will do that if you have just bumped for priming or whatever. You can do it many times with out shutting it off. But if the engine shuts down for any reason other than turning key of
It could be air leak in the suction side of the pump. He mentions that the fuel pressure gets unstable then it stalls. I've seen a truck with a bad pick up tube in the tank and would do something simi
1998.5 24V It starts fine and quick, runs strong then the fuel pressure will fluctuate and it stalls. It will not restart. I found the fuel overflow valve is getting stuck in the full open. Replaced the fuel overflow valve but it keeps happening. If I push the ball on the overflow valve it will start again.
