- Replies 20
- Views 8.6k
Dieselfuture 4 posts
Bullet 4 posts
Ranch96 4 posts
Evan 2 posts
I blew one with my horse trailer on the back going up a grade about 11%. My shorts turned brown and the air behind me turned black
Only compound turbos can spoil...singles won't do it.
Same problem...can't seem to bust 1100 with compounds. I've blown a boot off somewhere in the mid 50's and it scared the crap out of me...sounded like a 12 gauge went off under the hood. I'll bet bl
First time poster, long time reader. The knowledge on this forum is amazing and can’t thank everyone enough for it so thanks in advance.
I know this has been beat to death, but I couldn’t find my exact answers and don’t want to do this twice. The truck is used to pull a 24’ gooseneck full of cattle a few times a year through some short but steep rolling hills. Other than that it gets driven on the weekends. I want to get close to the 500hp mark without having to stare at my pyro. I was told a 62/65/14 and some 100’s would do the trick, but ive never ran a bigger turbo and worry about lag towing.
I’ve seen Carl’s compound kits and wonder if an Hx35/s472 or something similar would be better in the long run. They aren’t much more than the HTT I was priced. If the stock turbo isn’t going to pair well or is a pain to dial in I probably won’t mess with it. Thought about trying the 62 and using it later in compounds but it seems like a waste of money if I could start there now with the stocker and have a faster spool than the 62. I’m planning on getting studs and a clutch in soon when it warms up a little. Then on to the fuel and air. I’m sure both have their advantages but what’s the best option?
