Engine died driving down the road won't start.
- Replies 18
- Views 3.6k
Cummins_Crazy 8 posts
dripley 6 posts
Haggar 1 post
Evan 1 post
Crazy, Just keep a couple wrenches under the seat. You can bleed it on the side of the road if you have to. completely beats any of the alternatives. The big thing is if you are on it
Yes, that's why you see big guys keep reving it up few times after a race. Mine came close a few times, like it wanted to die but didn't. I have a mild set up and still i could tell it didn't like it.
The vent is the gray thing on the top left. It has no lines to it. Mine is the in tank pump basket. The OE looks a good bit different but I believe the vent is the same.
I was driving to work this morning and the truck just shut off and will crank but not start. Fuel pressure is reading 15-17psi on gauge. Any help would be appreciated. I changed the VP 44 probably 50k ago.
