Trans Pan Bolt Torque
- Replies 11
- Views 2.8k
IBMobile 2 posts
JAG1 2 posts
Dieselfuture 2 posts
cs15dah 2 posts
Rubber gaskets are notorious for leaking. I would switch to a fiber gasket.
That is the same as 13ft-lb. Snug plus, like a couple of ft-lbs, works sometimes but if you tighten the bolts any further there is the risk of tearing the gasket. The pan may be distorted, from a pe
If I might add, put the bolt in without the plastic washer and snug it up before welding, this way it'll be tight to the pan. Ether way the sealing happens on the outside between the bolt washer and p
FSM says 156 in-lbs. I used a Napa filter and rubber gasket when I did my fluid change. It seems that the bottom of the pan is slightly damp in one section, so fluid is very slowly leaking in one area. Before taking it apart and redoing the gasket, how much more could I torque down the bolts to try to stop the leak? 5%? 10%?
