1st post and need advice and or help ?
- Replies 13
- Views 3k
xFreightTrain21 4 posts
Mopar1973Man 3 posts
dripley 2 posts
Me78569 1 post
2002 5.9 dually 81,000 miles on the clock. Have several problems guys. But firstly I bought the truck 6 months ago and have put 18,000 miles on it but when the cold weather hit I came up with alot of problems. I'm pretty mechanicly inclined I just dont know where to begin my first 5.9 24valve and diesel for that matter. Its pouring oil like a drop every 10 seconds out of the crank case vent so I emptied the bottle and filter and that didnt help a bit. Also theres a small hole in the bottle I'm assuming from the previous owner? Next I have a hard start fuel leak issue sets down hill truck starts fine, tighten the banjo bolt still no luck. Cant actually see fuel leaking from the bolt or any lines but the truck will drip fuel over night on the passenger side where the engine and tranny bolt up? Then lastly my quadzilla is reading 48psi constantly hooked a code reader up and got PO236 and PO216 (I know vp44 death). And now and it's only on cold starts I'm getting white turning into blue smoke then warm it goes away unless I stay at like a constant 1800 rpm in 2nd then itll smoke blue. (No blow by) I use rotella and Lucas for oil
