- Replies 10
- Views 2.1k
Reaper22 3 posts
dripley 2 posts
01cummins4ever 1 post
wil440 1 post
Sounds like the strater might be failing. If the clicking is coming from the starter the contacts are most likely worn out.
I would just try replacing the starter contacts in the solenoid, mine did that a long time ago, and replaced the contacts, still cranking on the original starter at 350k, back then napa was stocking
On most bigger diesel starters there are 2 things that happen when the key is turned. 1. the bendix is thrown into the ring gear first 2. starter spins as the bendix is fully engaged or sli
Hey guys, I had a problem come up on my 99 on Friday. I came out to start the truck after it sitting for maybe 4 days to go dirtbike riding and the truck started at first, I moved it to the spot I load my bike and then the truck wouldn't start when I went to leave. I watched some videos and did some reading and got the truck to start by unplugging and re plugging the connector right out of the fuse box with a single brown wire. No loose battery connections and just looking around I couldnt find any loose grounds anywhere. I took the truck and it was fine the rest of the day, started fine probably 5 times. Today I went out and it happened again. No crank, clicks every time like the starter is engaging but wont spin. It isnt a relay click, definitely louder and more solid. Unplugging the batteries and letting the truck reset did nothing and neither did the brown plug the first time. Second time I unplugged it and blew it out and it started fine. Started 3 more times no problem.
Any help is appreciated!
