- Replies 13
- Views 2.7k
Threadzy 3 posts
ColoradoColt 3 posts
Mopar1973Man 2 posts
Haggar 2 posts
Popular Days
I tried to find the article, but didn't find it quickly. Have a good DVM. Set to AC. put one probe on positive battery terminal and the other on the negative. You will see AC volts. Th
I had this problem some years back and was able to resolve it for a couple years by moving the ground wire away from the alternator. The problem returned after doing a band adjustment on the transmiss
Check the ac voltage at the B+ alternator terminal; it's the big terminal on the alternator. I've seen lower voltage readings when testing at the driver's side battery. To test if ac volt
So to start here’s what I’ve done to try to fix it. Checked all grounds and connections, new batteries, new timbo apps. I don’t have any fuel pressure gauges so I don’t know if it’s a fuel thing. I am looking to get some today if I can. So the problem is once I get to about 43 it starts surging. It will stop as soon as I go back to 40 or under. The problem seemed to appear after I replaced my whole A/C system. And only when the Ac is on. But will keep happening even after the AC is turned back off. But if I never turn it on in the mornings, it doesn’t seem to do it. Although I never get too far about 15min before turning it on because of the heat here. It seems like when it started it was only at about 43-48 that it would do it and over or under it was fine. But now it’s anyspeed over 43. I would give it decent throttle to passed the bad zone and jump straight to 50 and it never had problems, now it does it even when it downshifts to accelerate harder. Any help would be appreciated. Almost forgot, I used code reader and found no codes. (There was one for apps signal low but went away after Timbo apps)
