New front end noise, how can I diagnose the front end?
- Replies 15
- Views 3.1k
JAG1 4 posts
Reaper22 3 posts
dripley 2 posts
Royal Squire 2 posts
You could also help confirm the wheel bearing failure with an infrared laser heat gun by comparing the temps on each bearing I used this method on our Tahoe, I couldn’t tell if it was the
I like the idea of the temp reading, gives me something solid to go off of. I’ll look into getting a temp gun.
Jack the axles and attempt to rock the tire up and down then left to right check for bad bearings. Even spin the tire feel for rough gritty bearings.
Hey guys,
I took my truck and my dirtbike out to the desert this weekend and since it was so damn hot we decided to take the trucks out for a little fun in the air conditioning. I went through some sand, did some hill climbs, nothing too crazy, used 4x4 on and off worked great. I did apparently dump a good amount of oil out of the vent tube going down a hill, though. On the drive home everything was fine didn't *notice* any noises but had the radio going and with the 5" pipe can't hear much anyways. Last night I'm driving home from my buddies and over the radio I can hear a growling and feel in the floorboard some vibrations especially over bumps. Turn the radio off, very noticeable growling in the cab and can feel a sort of whirring vibration in the floorboard. When I would hit a road marker the front passenger tire would clunk and felt like it steered the wheel a bit but only on one side. The growling got worse as I went home and even this morning pulling the truck in I noticed something is definitely off. It clunked turning into the driveway and clunked on flat ground. Strange to me that it came on so suddenly when my front end was solid before but I did hit some good bumps in the dirt. Do you guys have any advice for trying to isolate what might be causing the problem? I'm used to 1/2 ton chevy problems and over bumps it felt like bad steering but the growling and clunking on flat turns has me confused here.
Edited by Reaper22
