Vacuum pump elbow replacement
- Replies 17
- Views 9.1k
Bullet 7 posts
Sycostang67 3 posts
dripley 2 posts
JAG1 1 post
Thanks for the reply @sooxies! I did some more online digging and found this. It's the entire assembly of lines and fittings with the one I needed all hooked together and all brand new for $13.82 an
Yep that'd be my guess too. I just got mine in today. I'll get it changed out as soon as this heat eases up...98° today and feels like 113°. I'll can only drink half my beer before the other half e
Sounds just like my cabal owned bank...they accept my direct deposits but can't withdrawal cash. They closed up shop while the coronahoax is being played out. Bunch of peckerhands...
I popped my hood recently and found the vacuum line that runs from the firewall to the vacuum pump just laying there...still attached only to the firewall fitting that I previously replaced. On closer inspection of the vacuum pump side where it is supposed to be connected I found that the rubber 90° elbow that receives it has now degraded to the point of failure.
I've been looking online for a replacement rubber elbow but can't find anything specific to my truck...only come across HELP kits with several generics and ones that specifically fit Volvos and Mercedes. They all look like they might work OK but can't be sure. I'd really rather have the exact replacement instead of guessing at a cost for each wrong guess. Can you guys give me some ideas on where and how to find it? I appreciate any an all suggestions.
