Head Gasket....it finally happened......got LOTS of questions
- Replies 14
- Views 7.2k
LiveOak 7 posts
dripley 2 posts
Towrigdually 2 posts
sooxies 1 post
I'm going to have a look at the crank case vent tube once the weather cools off. I am hoping the exhaust manifold is not cracked when it gets removed but am just trying to plan ahead. The big concer
Here is @dripley thread on his replacement and @Mopar1973Man
For head work I’d say find a shop that does heavy Diesel engines, I had to do that when I replaced the head gasket on mine. Was cheaper, and I feel they did a better job. Got lucky and the head was in
This morning the wife took her truck to drop off some cayacks to my daughter and she is gone for about 10 minutes and she come back telling me there is white smoke coming from the exhaust. I got take a look, start the engine and sure enough a notable plume of white smoke (steam) is coming from the exhaust just idling. I immediately turn the engine off, pop the hood and open the oil filler cap and the crank case is pressurized slightly as I can hear the pressure escape when I removed the cap. (I think this is a secondary issue of mud daubers clogging up the crankcase vent tube as the truck sets 97% of the time) I pull the dip stick and there does not appear to be evidence of coolant in the oil so I take a look at the crank case breather tube and notice fluid dripping from the front axle. I look up and it is coming from the engine. Long story short, the driver side of the engine is soaked in what appears to be a oil (possibly coolant).
I have not done a cooling system pressure check yet but I am about 99.997% sure the head gasket is blown. It is probably the original head gasket that has corroded/rusted through as the truck has never shown any signs of over heating and has always run well. It still starts right up and aside from the steam show and engine leak you would never know.
So.......time for a head gasket.
Nothing is ever that simple so I am trying to plan ahead for when the head gets pulled. I am going to replace the 21 year old head bolts with head studs. What would be the best head stud to go with?
I am thinking there is a possibility of a cracked exhaust manifold. If that is the case what would be the best after market manifold to get?
Also thinking about getting a set of exhaust manifold locking bolts.
This would be a great time to check the injectors for pop pressure & spray pattern. (stock injectors currently installed & engine has just under 180,000 miles on it)
If what appears to be oil leaking on the engine driver's side, probably need to check to make sure it is not the tappet cover leaking due to the obstructed crank case vent tube. Basically, probably should replace/reseal most if not all of the gaskets.
I'm keeping my fingers crossed that the head is not warped or cracked but will probably at minimum need resurfacing as will the block deck (at least cleaned up really well).
I remember Mike had to do this awhile back but darned if I can find his post about it. Mike, if you could post the link to when you replaced your head gasket, I sure would appreciate it. Any other thoughts, suggestions, or recommendations welcome.
With 3 herniated disks and not much if any shop space, I am going to let the local repair shop do this so I want to have as much of parts and other things thought about and on hand as possible. Thanks!
