New Injectors now Surging
- Replies 36
- Views 8.8k
beans20 16 posts
Mopar1973Man 8 posts
Me78569 4 posts
Unreal Summit 3 posts
He means the fuel lines. They tighten against the cross over tubes and compresion seals everything tight.
Upload the video to youtube and post the link here. Pause jus a bit and video frame will pop up. Like this...
Dripley is right on. Yes you want to tight the lines FIRST. Crossover tubes will be pushed into the injectors and centered up and sealed before you lock the injector in place.
I need some help! I just installed 7x.011 DFI injectors, I currently have a quadzilla with custom tunes as well. After I installed the injectors I’m getting a surging only when I press the clutch in to come bring the truck to a stop. Idles just fine no issues, no white smoke no ungodly knocking sounds. Idk what the issue is. I reset the apps after injector install since I unplugged it to install them. This surge happened with and Edge EZ as well. Can anyone help me narrow down the issue? Also no CEL codes.
I should add this is 2000 Dodge Ram 3500 has approx. 181k miles.
Edited by beans20
