24v injector install
- Replies 19
- Views 5.8k
dripley 5 posts
Unreal Summit 3 posts
Threadzy 3 posts
dave110 2 posts
Popular Days
Although the common rail runs higher pressures, I don't think that is as much of a factor as is the contamination the edge filters must deal with. I think the key is the phrase "common rail", which
Being that the wife's truck had over 185,000 miles on it, I decided to replace the crossover tubes out of an abundance of caution. When a friend and I installed the F1 Mach 1.6 injectors, we decided
Mine cross over tubes are original with 510k miles on them, 4 injector changes, a couple of removals for other purposes and I would not hesitate to use then again. The steel they are made from is the
Got my injectors in the mail Monday. They didn't come with crossover tube o ring. I think it's best to replace them right? I don't believe I should reuse the old ones?
Edited by Unreal Summit
