Thinking about front and rear Eaton TruTrac's
- Replies 26
- Views 6.2k
LiveOak 8 posts
Joe_Pool 7 posts
That Guy 4 posts
Towrigdually 2 posts
BEWARE... Tire conversation. That's because of the wider tires. That spreads your axles weight out over larger square inch surface. Like walking on a weak roof you throw down a sheet of p
I have experienced the front axle load of the Cummins more that once. It will instantly sink to the axle/frame given the chance. Last time I was on scales, F~4300, R~3000. Narr
Unpredictable is an automatic locker. You are going up a steep switchback road on the side of a mountain in a truck with nothing in the bed in a light drizzle, start to slip a little... next thing you
I am looking at having front and rear Eaton TruTrac's installed in the wife's and my truck. Getting really fed up with getting stuck/tire spine on damp grass and poor off road manners especially in mud & steep forestry roads.
I am trying to figure out an easy way to determine what spline axles are in each of the axles. Both trucks I am pretty sure I have 3.54 gears in both trucks.
Any comments, opinions, suggestions, and recommendations welcome.
Edited by LiveOak
