differential & transfer case oil & seals
- Replies 12
- Views 4k
Mopar1973Man 3 posts
NIsaacs 3 posts
dripley 1 post
Joe_Pool 1 post
I use Lube Locker self sealing gaskets -- no sealer required and they are reusable (tend to check on a regular basis).
Get the vehicle ID number and go to a Dodge dealer parts or service department; see if they will print the factory build sheet for it.
You don't suggest what? The OP asked how to tell if the truck had limited slip or open diff. The question was in reference to friction modifier or not. My response was just get oil with th
I have a 2001 3500 4x4
what would the proper fluids and sealing materials for the transfer case and differentials?
