2001 2500 Rapid Torque Converter Cycling
- Replies 45
- Views 9.2k
Bfranz 23 posts
Mopar1973Man 9 posts
Dieselfuture 2 posts
Great work! 2 posts
I really don't see any converter cycling in that video. I'm trying to make heads or tails of it, though to be honest. It looks like you take off from a stop, and at the 1-2 shift, it shifts, but then
Your TV cable is a little tight. Loosen it until WOT shifts occur at 2800 rpm and see if that changes anything (besides the shift point).
Alright, it seems as if the issue is fixed. I took it back to my transmission shop and they replaced the speed sensor (again) and the “external transmission harness” (from what I gathered he meant the
I have a 2001 Ram 2500 with just a little under 320,000 miles. When I bought the pickup last year I drove it home and it started doing the rapid torque converter cycling. When I got home I cleaned all the battery terminals. No help. I zip tied the ground wire to the frame of the alternator and it cured it. Then I was getting random dead pedals for about five seconds and I finally just got around to doing the ground relocation on the drivers side of the engine. I left the charge wire to the PDC because I’m not sure how to delete that (if anyone could give me input on that too that would be great). Now that I did the ground relocation I have intermittent dead pedals and torque converter surge again, as well as kicking out of overdrive. I just had the transmission rebuilt about a thousand miles ago too. Any input is greatly appreciated. Thanks!
