High EGTs when towing
Im sure this has been asked but I can't find a thread. I have an 01 2wd 7x.008 153°VCO injectors, BHAF, HX35W turbo, banks brake with 4" turbo back exhaust when towing 12k lbs with no tuner my EGTs are pushing 1300° on a long climb but stable. With my superchips tuner it's much higher, too high. I am trying to figure out what i can do to get these down, if not the truck has to go.
  • Replies 55
  • Views 14k
  • here was my messing with it.         Keep in mind that 320 bar is not creating extra wear.  310 stock is only the pop pressure, the pump continues to build pressure's much hi
  • Dieselfuture
    Dieselfuture
    From my own experience I can say 7x10 at 320bar with mild set up is where it's at. To each their own, but I had few different types/sizes of injectors in my truck and by far what I have now I love bes
  • I have no coolant temp issues. Maybe 200-210. So i tightened the rod on my wastegate until it had no play then went a little further. Im now getting about 30psi of boost on hard acceleration in st
2 hours ago, Zamboni said:
So clamping the line off should stop the wastegate from functioning. Correct?
Yes
Not sure where the rest of the posts went here but here is the question.
At what point do i need head studs?
Yeah lots of posts disappeared. Head studs are always a good idea I believe it has more to do with high timing, load at lower rpm. So if you drive nice you should be fine without studs till you get over 400ish hp. Jmo
I am receiving emails for posts but see no posts??
On 11/3/2020 at 4:36 PM, Dieselfuture said:
Like @NIsaacs said maybe 28 I was just judging from my 60hp injectors I had, even on level 0 I could have swore it went to 30s
You can put a plug in turbo housing where the elbow is just to see if you get higher boost, if not then maybe your wastegate is not fully closed.
I can't stand the stock setting so I never use it,  so yes, I can't remember either.:)
So I did an unscientific test yesterday. With Edge Juice on stock/level 0, I checked the numbers on an empty trip with my dump.  First hill in 6th, at 1800 rpm, I went wot for about 30 seconds. Max boost, 24 psi and EGT's 1070 at 1700 rpm. Second hill, I dropped to 5th, went wot for about 30 seconds. Max boost 30 psi and EGT's 1260 at 2500 rpm.
So my boost fooler works on stock setting. This is with RV injectors and K27 turbo.
So on stock setting it needs RPM to develop any power or boost but EGT's go up. After I loaded, I went to level 2/tow and on a small hill in 6th at 1800 rpm I went wot for about 20 seconds, 32 psi boost immediately and 1250 EGT's at 1900 rpm.
I picked up 12 yards of mulch.
OK, got the adrenaline installed, had DAP set up my 7x.009 SAC injectors at 320 BAR, truck runs much smoother. Copied over DD tune from V2 article for test run and have to say its a crazy difference. Still trying to understand what everything is in the custom tuning but I'm figuring it out. Did find a boost leak at the first coupler, bubbled pretty good at 20psi, fixed that and cranked it up to 40psi and that blew the plastic cap out of my homemade boost leak tester, its tight now. Ran it down the road and easily hit 40psi of boost according to my data log, stuff happens so fast I don't have time to look at gauges, good thing it logs data. It did log a peak EGT of 1375* but I did forget to turn on my defuel setting which is at 1250*. Just want to say thanks to those that helped me out, I have been looking at the Adrenaline for a while just couldn't bring myself to spend the $$, glad I did. One thing I did figure out is DAP is about 5 minutes up the road and they are very helpful. Oh, and don't do initial test drive on wet roads because once it takes off you lose all traction.
One issue I do have though and I haven't called DAP yet, when I have my high idle set with a 30 second delay and my warm up mode on to 120* as soon as it kicks the idle up the truck shuts down and sets a MAP sensor code. I have to un-plug the MAP sensor to get it to start again. If I don't run warm up mode it is fine. Anybody have this happen?
Very important not to try and build a power tune when its wet or icy. Very dangerous mix. I'm actually now tuned down to level 2 and my Daily Driver tune is very aggressive on the down low and if there is any water or ice the game is totally over the tires spin easy. @Wet Vette seen that on my last trip to Lewiston, ID.
Make sure you don't have OEM high idle enabled.  that's what it sounds like.
Also don't want to run high idle if there is the ECM software enabled. If your using the Mopar1973Man high idle kit you should shut off the Quadzilla High idle.
My truck don't have OEM high idle
I have never had any high idle. My Banks brake usually closes when cold to assist in warm-up but I disconnected the wire for that.
What do you mean here?
You sure?
Like myself I can run the Quadzilla high idle in the summer as long as the IAT is above 32*F at start up.
My truck has never high idled. I start it and it runs at 800 RPM.
If the Cummins ECM software is enabled you can't run the Quadzilla High Idle too. The two system tend to get in conflict and then stall out the engine. I typically turn off the Quadzilla high idle in the winter time and use the Mopar1973Man High Idle switch. This way I still can control high idle for the Cummins ECM and just shut off the Quadzilla. There is NO WAY to shut off the ECM software once its enabled. You would have to go to a dealer and have your ECM reflashed to disable the high idle function.
All about that system...
Apparently my high idle has never been turned on. My grandpa bought this truck new in 2000 and I am the only person that has ever worked on it other than a new overdrive by the dealer when still under warranty. When I first got the adrenaline installed it did work a couple times but I wasn't running V2. Maybe I will go set it back to original Adrenaline software and see what happens.
Stand by
Might make sure you up to date with the most resent flash files.
OK scratch the warm-up mode comment. Was apparently just some random thing that happened while I still had it in the shop. Works fine now on old setting and on V2. Weird.
I will let you know how the original EGT problem pans out as soon as I tow my trailer again. Maybe I will go tow my buddy's skid steer just to try it out.
Once I get my tow tune set up anyway
If something weird happens... To reboot the ECM you just got to turn off the ignition and wait a 30 seconds to full minute. Then when you restart the truck the ECM and the Quadzilla both do a fresh reboot.
Interesting.
This truck has only seen winter the last 2 years of its life. My grandparents wintered in southern Arizona up until my grandpa couldn't drive anymore. I don't use it much during the winter either, I mainly use it to tow my 5th wheel and a couple dump runs here and there. It has never had an ECM re-flash, like I said I have done all maintenance since new. Only has 126k miles.
