High EGTs when towing
- Replies 55
- Views 14k
Zamboni 22 posts
Mopar1973Man 16 posts
Dieselfuture 6 posts
Me78569 4 posts
here was my messing with it. Keep in mind that 320 bar is not creating extra wear. 310 stock is only the pop pressure, the pump continues to build pressure's much hi
From my own experience I can say 7x10 at 320bar with mild set up is where it's at. To each their own, but I had few different types/sizes of injectors in my truck and by far what I have now I love bes
I have no coolant temp issues. Maybe 200-210. So i tightened the rod on my wastegate until it had no play then went a little further. Im now getting about 30psi of boost on hard acceleration in st
Im sure this has been asked but I can't find a thread. I have an 01 2wd 7x.008 153°VCO injectors, BHAF, HX35W turbo, banks brake with 4" turbo back exhaust when towing 12k lbs with no tuner my EGTs are pushing 1300° on a long climb but stable. With my superchips tuner it's much higher, too high. I am trying to figure out what i can do to get these down, if not the truck has to go.
