Can't get front brakes to fully bleed
- Replies 13
- Views 3.4k
Mopar1973Man 4 posts
IBMobile 2 posts
That Guy 2 posts
hdpwipmonkey 1 post
My new set of pads and rotors are being particularly recalcitrant, spent nearly 2 hours trying to bleed and still not quite right. I did rebuild the calipers with new seals and pistons and it was fairly clean inside. A touch of grease and the new stuff was in with no issues and no leaks. I had never rebuilt calipers before, is that maybe at fault?
Went through a big bottle of brake fluid. Did a gravity bleed, had someone help me power bleed (both using a version of Mopar1973Mans pickle jar), tried bedding the new pads and rotors. Went several more rounds after the new fluid hit and bubbles were gone. Still can push the pedal to the floor without too much fuss and the rears will even lock up, the front just aren't doing their part. They are working, I can hear the tires scrub and the slight smell of warm brakes as well as being warm to the touch. They certainly do not appear to be dragging. I even wiped down the rotors and pads with brake cleaner (again) after the 2nd time I came back from trying them out just to be sure. There was a little pad residue but nothing else, no change. Pedal feels plenty firm.
Ideas? Keep bleeding? They certainly worked fine before I started working on the front end.
Edited by That Guy
