Electrical questions/troubles
- Replies 31
- Views 6.9k
Dumb A 8 posts
JAG1 5 posts
IBMobile 4 posts
Mopar1973Man 3 posts
You're fine @Dumb A. @JAG1 is just covering his A for when he hijacks your thread. I personally would never do such a thing.
bovine excrement
I posted a minute ago and everything was deleted on just an edit for spelling. Even Dumb A's post that I quoted. What's with that? Basically I made up the rules to make the OP feel
02 ram 3500 4X4 manual 6 speed. I bought it in sad shape, wouldn't start. New items are batteries, battery cables, starter, alternator. At this point it would start and run, instrument cluster worked. Still no charging. I tested voltage coming from PCM, blue wire to ground=0. I had checked continuity of green and blue wires to make sure they weren't eedshorted or open. I'm assuming PCM was bad. At this same time I decided I would charge the batteries up. I removed them and charged them. Upon installing them I accidentally shorted black and red together on the passenger side with the driver's side hooked up. Then when I started the truck it ran but no bus appeared and no instruments worked. I installed a refurbished PCM and got 7 volts on the blue wire to ground, still no charging or instrument cluster. I have a cheap obd reader and when I leave it hooked up while running all my gauges work. When I unplug it they stop working. Also getting a 1698 code that keeps coming back.
I want to thank all of you for helping this far,I couldn't have done it without you. I did download the service manual but I'm not very good at reading electrical skematics. This is the first post I've ever done so be patient with me, thanks...
