- Replies 77
- Views 11.8k
3 kids in diapers is enough to melt anyones smeller. As I remeber there might have been some white smoke coming out of a couple of mine at the same time.
Not typically the turbo that explodes first, the crank/rods/pistons have a much lower tolerance of RPM. Think of it this way as long as the turbo has oil feed it's sort of ok but feed it e
I agree, and I doubt a manual would fare much better at the task. Stall stopping was brought up which is why I mentioned it. As you said the only good way to stop a runaway is to block the air intake.
I replaced my turbo with this one.
http://theturboplace.com/-S200GX-E-Dodge-Ram-Upgrade-Turbo--12769880001_p_290.html
And replaced the manifold with a stock one. It had a crack in it at on the flange where the turbo mounts on.
Now I'm getting a plume of white smoke upon acceleration. Have't tried driving it.
The truck only has just over 100k miles on it.
Fuel pressure is at 15 PSI at idle. Which is what it was before.
I'm running Bosch RV 275 injectors which I put in in Oct 2018
I have no error codes.
What should I look for next?
Any ideas would be appreciated.
Edited by leety
