- Replies 25
- Views 6.1k
DRGABE 10 posts
Mopar1973Man 7 posts
dripley 3 posts
Doubletrouble 2 posts
When my ecm went WOT at startup was one of the many symptoms I had. Did not do it every time. Sometimes it would go WOT on its own or when I touched the throttle. Pretty much had a mind of its own. A
Then my 3 articles about this topic.
Basically the ECM is shot and will require to be pull and tested and repaired. The articles above are to prevent future failures or testing for conditions that might cause a failure. Sine
Any help appreciated. 1999 24v air dog lift, timbo apps, edge comp box.
Start the engine and it runs up to full throttle without pushing the pedal. Is this an ECM issue? No codes thrown, thottle cable intact. I'm at a loss here.
