pulling to left while accelerating
Wondering if anyone has gone through this issue before or any suspension gurus out there?
I've been in the process of getting this front end tightened up and pretty much have it were I want, now without all the wandering and whatnot I'm noticing out on the highway while under throttle it's pulling to the left.
Pretty much new front end other than control arm bushings & ball joints which have no apparent need for replacement, although they could be original as far as I know.
I've replaced rear spring shackle bushings awhile back because of a uneasy fishtail feeling I got last summer while towing and noticed they were pretty worn/cracked. I'm still not completely convinced something else isn't screwy back there but can't find anything that sticks out, those bushings helped a little but just doesn't feel as stable as I'd like, not like my old 02 chevy 3/4, and really not as good as my last 08 1/2 ton!
Anyhow maybe related?, the lt. pull under accell., And the fishtailing?? Like something in the rear end loose, but don't see anything obvious.
 Anyone ever gone through anything similar?
   Thanks!
  • Replies 37
  • Views 5.6k
  • My wife was more than happy to oblige. But she lost the smile on her face when she realized I was not going to get under the truck.
  • The latest trend, seen several running down the highway, is wheels and tires so deep and wide sticking out the sides of the truck. There must be 6 to 8 inches out past the fenders without any mud flap
  • I don't think I've come across that statement in a dodge forum before 😉
I finally got around to doing the power braking test looking for rear end movement, had none that I could tell.
The mystery resumes : {
 This may be a shot in the dark but, try checking the frame in Front near all attaching/mounting points such as suspension, steering and so on. A friend of mine had frame flex in front causing it to handle funny. He installed some sort of brace in the front and it fixed it. Not sure what or where it was though.
Well the only brace I see a lot of people using is that sector shaft brace , correct me if I'm wrong? I already have one, not sure how much it helped? It supposed to help stiffen up the rails. Also have a front receiver hitch, (partially welded on) so I'm about
Braced out as far as front end, lol !
Still no entirely convinced that rear end isn't moving, I'm just not seeing?
   Thanks for the input!
Edited by dieseldon
Lets say all the braces I found out traces are just hanging weight and no longer used. My landlord at my other shop had one but the bearing failed. I took one off a 1 ton Dodge which the box was still sloppy. I used this steering box while my Blue Top was rebuilt (bad shaft with a nick in it which kept damaging the seals).
Myself I've never used or needed a brace. I've never used over sized tires. I'm all stock sized (Early 2nd Gen). Where the problem comes in is over sized tires. The amount of force needed to steering the tires on the front axle takes quite a bit of force which pushes or pulls on the pitman arm. Hence why the output seal will fail. Since I'm technically undersized I upgrade to a "Quick Ratio" steering box and still don't the brace.
  • Blue Top Steering Box ((Quick Ratio)
  • No brace used in 426k miles.
  • Stock steering box last 350k miles.
  • Running on 245/75 R16 tires (30.5 Inch)
The latest trend, seen several running down the highway, is wheels and tires so deep and wide sticking out the sides of the truck. There must be 6 to 8 inches out past the fenders without any mud flaps. They look like they rolling on toilet paper rolls. It's very weird...... it seems one guy started it and then others have to copy. Got to be hard on the wheel bearings. To add to it they are driving extreme aggressive like they idiots or something. :cookoo:
1 minute ago, JAG1 said:
The latest trend, seen several running down the highway, is wheels and tires so deep and wide sticking out the sides of the truck. There must be 6 inches out past the fenders without any mud flaps. They look like they rolling on toilet paper rolls. It's very weird...... as seems one guy started it and then others have to copy. People are weird.
Now actually try it...
Being I had my stock aluminum mags crack I bought a set of modular mags 16x7 wheels but the offset was wrong and the tires stuck out a mere 1 inch. Now couple that with 3 days a week driving over 1,100 miles. With in just about 15 miles the side windows are covered in so much mud, road grit you can't see out your side windows to look in the mirrors to change lanes. This is why I went hunting for the early 2nd Gen wheels that are 16x7 with proper offset to get the tires back under the fenders. No longer have this issue the road grime is now only on the doors not on the glass.
So for all them with them hanging out they never really drove there truck like I have and I just giggle and laugh when I see one with the windows out washed out with road grime.
I'm not makin' this up Mike... I saw a jacked dually yesterday with wheels so wide they stuck out at least 8 inches past the fender, front and back mind you, he sped by only so he could tailgate a small car at high speed with the rest of the tailgaters. I was amazed at the amount of aggression.
Yup, I see a lot of that between the larger cities like Lewiston and Boise. :rolleyes:
1 minute ago, AH64ID said:
That’s not a new trend, unfortunately.
Very true. I've heard nicknames for this style and its something I can't repeat here.
 So I'm not doubting what you're saying isn't true.
 I run stock wheels and tires, no lift, everything seems fairly tight now (not much slop) for a second gen dodge??
Aligned to specs , maybe I'm just too picky or I'm used to driving a GM truck that really drives more like a luxury car than a truck?
I thought the reason for those brace's was for possible frame flex/twisting?
I guess if the bearing fails I might toss it and see if there's a difference?
 I've been reading article after article about people fighting these junk front ends and really haven't come across any difinitive answers, I've been throwing parts and money at this thing since the day I bought it. (With some improvement) I'm sure I could easily spend another $1k in parts that may or may not help. My son's '99 is in worse shape than mine and he's been kinda doing the same thing.
 Are you saying a blue top quick ratio steering box might be the answer to my problems? I'm having a hard time equating my current issue of wandering to left under accell to a steering box, although probably would be beneficial overall?
 I really don't think my box is worn out, son's might be another story? His has a history of puking fluid, undiagnosed issue.
 Thanks!
Never had any suspension or steering issues.
Now steering boxes can be mis-adjusted. I got mine from Blue Top and had just bit too much slop for my taste. Like Ryan told me there is no way to adjust a box on the bench and set sector adjustment perfect. He tends to be on the loose side. I added about 3/4 of a turn tighter and problem is gone. Tight box. After 350k miles my box was still tight and in excellent condition. Only needed at new input shaft because rust pitted the shaft caused the leak.
Life continues on the repaired BLue Top... 426k.
I'm definitely seeing an increase in it
he drives so slow nothin' ever wears out. The whole town won't go anywhere when they see him out and about squeakin around town.
🤔 Has anyone ever actually ever seen That maroon dodge on any public streets, or is it just sitting on jack stands running 'round the clock??
I’ve seen it twice.
Once we met in Boise, and the other time I passed him as we were headed camping. It wasn’t too far from his house thou :lol:
Edited by AH64ID
I've driven it once but Mike set the Quad to stock before he turned it over to me.:burnout:
