Cutting Out Under Hard Acceleration/Above 68 MPH+ 2500 4x4 47re
- Replies 57
- Views 11.3k
MarkG 21 posts
Mopar1973Man 10 posts
wil440 6 posts
IBMobile 4 posts
I had similar problem, thought it was vp, between changing injectors, cleaning up wiring, rebuilding alternator (can just replace with a good unit) my surging went away and later I did the WT mod and
Only Fass is developing as unreliable as compared to others such as Raptor or Air Dog which are doing okay in spite of some issues. Like anything in life everything has some degree of disadvantage and
Have you tried the push-n-pull test. You do this with the truck running; you push and pull on every part of the engine wire harness and all connectors.
Howdy! The truck: '02 2500 4x4 with the 47re transmission. Gonna do my best to bang this out in the most concise way possible. The problem: under hard acceleration from low speeds to highway speed and also cruising along above about 68 MPH I am experiencing what feels like a hard shudder or very quick cut outs. Recently preformed the grounding mod described in W-T's thread "Ground Reference VP44,ECM,PCM,PDC plus TC lock/unlock". Batteries are fairly new and terminals are clean. VP44 and lift pump both replaced at the same time a few years ago. VP44 came from Industrial Injection and I usually run 2 stroke oil in the fuel. FASS Titanium 95gph lift pump. Just changed the filters for good measure. Years ago I installed RV275 injectors. Never did get around to buying the Smarty, the truck still has the stock tune. I have a scan tool, a Bluetooth unit that connects to my phone and use with the OBD Fusion app. There are no codes present when scanned. I've reset the APPS. I'm frustrated and don't know what else to do and really look forward to hearing any input and advice you may be able to offer. The truck has been taken care of. I do service and repairs myself and there's about 150,000 on the clock. Here's what I've come to: I think the VP44 is going bad. It was always very noisy, the part looked old and beat up and overall I had questioned this part from the moment I pulled it from the box. PLEASE HELP!!!!!! and thank you!
