- Replies 36
- Views 7k
Mopar1973Man 10 posts
jag 10 posts
Dieselfuture 4 posts
dripley 3 posts
Well the Ram just ate another ECM. Must be high in protein.
The first ECM went with around 3500 miles from new in 2000 when I bought it. The dealer replaced it & never said what happened.
The second ECM went wild & through just about every code you could list. I think this was in 2008. Not repairable at the time.
The 3rd ECM got replaced with a used one from a 98.5. I got the used ECM & PCM together from a guy in Montana. They would not work in my truck together, So I tried just his ECM & my PCM & the marriage was formed. That work fine up to about 2 years ago. Then the WTS light, fuel pump & grids started doing their thing. Then recently doing the WOT at start up & making me wait for 10 mins. before it got it's head together. So now that one is at the ECM Dr. getting repaired. I hope this is the last time around. Just can't seem to get this new engine broke in at this rate.
Better days ahead.....I hope
