- Replies 26
- Views 3.1k
wil440 9 posts
dripley 4 posts
Mopar1973Man 3 posts
Scarecrow 3 posts
All sorted.......... I decided to check for bare shorted wiring around the column, all ok there, took a look at the wiring diagram again and checked for stuff earthed/grounded at G100 left fender and
My '53 Sunbeam had the letter "B" on the the hood release.... Took me awhile to figure out it meant bonnet. lol of course the turn signals were little flags that stuck out from the fenders.... w
Had this issue two years ago, replaced the multi function switch and still had the problem. Turned out to be the ground under the drivers side battery tray. This is a very important ground and is in a
Just when I thought my truck was pretty sorted
Indicate to make a left turn and the wipers come on and stay on until the turn signal is off, all ok when indicating right, hopefully just a problem in the turn switch or wiring around the column, indicator doesn't come on when using either wash/wipe or wipe
