- Replies 45
- Views 10.4k
Mopar1973Man 11 posts
Ravewolf 11 posts
Marq92 6 posts
LorenS 6 posts
Already got one on the way. I just wish I knew where the hell the old one flew off to. I remember pulling it out, watching it pop out of my fingers, and what I thought was dropping underneath the truc
This is an indicator of slow VP timing, like really slow. Are you sure the pump key is in place, correctly, and or the right one?
Always been fast even at +5° between bands, just looking for better efficiency. Been testing this for about 2 weeks now. By 3rd gear I can out right smoke the rear tires then bark the tires in 4th. Fu
Ok, so I finally got my truck back on the road after having to get another injection pump. Hopefully nothing else major goes wrong. At this point, I've replaced every major thing that could go wrong (minus the pcm and ecm). But I digress.
My latest problem is whenever I drive the truck, if I don't have the tuner set on a higher level, it bucks, sputters, and blows white smoke.
I'm 95% sure it's tuning related. I'm getting great fuel pressure and flow, and my injectors have all new tips (I rebuilt and pop tested them myself at school), and seals.
I'm not sure if my specs are in my profile, but here they are again:
FASS 150gph pump, 1/2 line from pump to injection pump, Hamilton cam (so I was told,) 150hp injectors, and a 66/65/.84 turbo that has no wastegate, and dumps into a 5" exhaust all the way back. No muffler or anything.
Long winded, I know. But where should I start on my quadzilla settings?
If this is in the wrong place, feel free to move it.
Thanks again for the help!
