- Replies 30
- Views 4.6k
Krlspokane12 12 posts
Me78569 7 posts
Mopar1973Man 5 posts
dripley 3 posts
Please remember that DDP historically runs 155* spray angle nozzles. DDP injectors are historically Smokey and hot. If it quacks like a duck.... Agree you should hotwir
Hot wire the VP44 and see if there is change to idle performance. If the VP44 is bad it should stay the same if it changes its possible wiring or ECM.
This is why I would suggest hot wiring the VP44. If the ECM is the problem it will idle normal with the ECM disconnected. If its the VP44 then the problem will still be there.
So, I decided to start a new thread on this. My truck has been running like crap since I installed my 100hp ddp injectors. I know they set the pop pressure at 290, which is low. But when it's idling, or driving under light throttle it almost sounds Iike it has a fuel knock. Not sure what is going on, but is there any reason why I can't pull them and set pop pressure to 320? Not sure if this will help or not. They are really smoky, which is the nature of them I guess, but it leaves a slight clearly visible haze even driving under lite throttle, so not sure if there are other underlying issues. Truck does have a airdog 100 and a new vp.
