Gen 3 track bar conversion
- Replies 41
- Views 11.6k
wil440 17 posts
Mopar1973Man 9 posts
Doubletrouble 4 posts
Tractorman 2 posts
Here is an early 110, all windows are sliding, if you look at the front side windows you'll see the back sliding peice, changed after about 1987 or 88 but was like that for 40 years plus https:/
Plenty of practice getting Cat bottom roller and roller guard bolts out of track frames upside down I'm afraid, my usual trick is to drill out and leave say a 1/16th if the bolt diameter is large enou
plate should be ROLLER SKATE I can't believe in the land of the free and V8's that Smart cars have even been allowed off the boat, should just toss em overboard with the used orange crates or just
I've had a Gen 3 track bar and conversion bracket on the shelf now for over 10 years, originally bought for my 3500 but never got around to it
I've been getting more and more ~~~~ed off with steering wander on my 2500 recently so decided to bite the bullet today and fit the 3rd gen bar and bracket as there is a tad of wear in the ball joint end as per usual.
Axle end bolt seized solid in the steel sleeve in the bush then stripped the welded nut in the steel plate keeper GGGRRR, ended up drilling the bolt out, luckily I got it just right and didn't even damage the bush sleeve or the bolt holes in the axle bracket. All off and on the floor ready for tomorrow
Got to find a replacement bolt and make a new captive nut tomorrow but it looks like at first glance that a 3rd gen bar has a bigger bolt at the axle end anyway will know better tomorrow when it's light.
Job should have taken a couple of hours max, took 6 hours to drill the bolt and split the ball joint, slowly slowly catchee monkey, no broken drills, smack in the centre of the bolt and to make matters worse just as I'd gone past the point of no return the phone rings and a job on a bobcat skid steer 45 miles away... oh well that can wait till truck is done
