Looking for Staff Members
1999 dodge Cummins 2500  truck has 168k with a DDT tranny installed about 120k  miles ago . It has a smart controller installed to keep the torque converter locked up for the BD exhaust brake to slow me down while hauling my slide in camper . Third / forth gear lockup at 50 mph kicks out at 30 mph.  275 hp Rv injectors and edge  set on high about 300 hp. Tranny built for this much horsepower. This my set up.  10 amp fuse in PDF blows when key is turned on.  Has code p0753.  Relay is good  horn test.  And pin 21 on the PCM READS 33.3 OHMS. Pan has not been down yet.  I need good advice on what to do next ?
  • Replies 81
  • Views 13.3k
  • Three things come to mind...   One: Most shops are absolutely buried right now. All of the shops that I deal with and build for are out at least 6 weeks right now. It is the busy time of yea
  • Turbo Terry
    Turbo Terry
    Alaska is not for everyone  winters are long cold and dark. Summers are very nice but pretty short. Tourist come and marvel at its beauty then go home little do they know what it’s like in the winter.
  • Turbo Terry
    Turbo Terry
    Picked up truck Thursday am.  Drove it home 55 miles Shifts perfectly exhaust brake works as before. He had no problems  with the mods . Valve body was in bad shape. Either the governor pressure solen
It goes into a shop on the 28 th of may. Worse than making a doctors appointment. They were /are three weeks out on their work schedule it seems. My days on the creeper in my garage ended a couple years ago when after left hip then left knee but the right knee replacement cinched the deal   No more creeper. If they can’t won’t do it my 34 year old stepson will have to do it for me.  But he has a wife job life and kids and I don’t want to be a pain in the neck but I do take care of his kids a lot. Pay back time ?
Turbo Terry, I must say in your case I would not be going to a shop. I have seen nightmares begin inside trans shops. They could make it worse. Please pay your son in law instead of the shop and will be often more per hour than most of us make.
I once had a truck so desirable for resale I discovered later the service shop acted like it could not be understood what was wrong. They where hoping to get me to trade it in on new.
Nice to see W-T hanging around. Thank you for contributing. :thumb1: Also if your wrong about something is when the big chicken comes out and pecks you to death . LOL
I hear you. I’m going by the shop tomorrow to see how receptive they are to doing  just what I ask and not try to over do it all   I shall see what the level will be. First shop said it was a electrical problem and they couldnt do it because it was past their expertise. Really I told them what I thought it was.  They never even dropped the pan duh
Ok a update. Third shop turned me down on a pan drop fluid filter and two parts needed to fix my truck.  They never even seen the truck but wouldnt do it. Why won’t these shops work on these trucks. It’s very strange.  So I ordered a GM solenoid and transducer should be here in a few days. Off to Napa for some atf + 4 and gasket and filter. My neighbor and stepson will be my creeper monsters and I will the topside tool man . Hopefully it will fix the problem. Results to come in a few days?
Turbo Terry, I don't know what to say here. Why would a repair facility turn down work? These 47RE's are quite common so the reasoning eludes me.
I hope your crew is successful, please post with additional data as you proceed.
@Dynamic is certainly a notable authority.
Yes it’s very strange that they should turn down work.  I wonder sometimes what kind of work that they want. I’m baffled
One: Most shops are absolutely buried right now. All of the shops that I deal with and build for are out at least 6 weeks right now. It is the busy time of year, plus we're in a strange economic climate right now where everyone seems to have money, and is willing to spend it on their vehicles.
Two: An unfortunate number of shops or, more accurately their "technicians" couldn't diagnose their way out of a wet paper sack. The diagnostic component of automotive repair has largely been lost in favor of parts hanging. Just throw enough parts at it, and you'll eventually find the problem Sad...
Three: Most shops that have been around for a while (long enough to know better, anyway) won't want any part of a customer's pre-diagnosed project. Nine times out of ten those end poorly.
Strong young guys with the wrong tools dropping a valve body is a recipe for broken bolts and a bad valve body. The bolts must be torqued correctly and the plastic rooster comb on the linkage is delicate. I would inspect the wires inside the tranny very closely for pinches or rub through first.
We are dropping the pan to replace governor pressure solenoid and transducer. Two small parts known to go bad in 47 Re trannys.  New filter  and  pan gasket and fluid.  We are are not taking the valve body down or off at all  so shouldn’t  be a problem
Just slightly off topic;
I drove IBMobiles truck with the Dynamic Transmission... I will have to say it drives like a dream piece of equipment. Then have to go home from camp with my stock 'slusher'... what a bummer. Im still having withdrawals.
In my early days I have had a lot of bad luck with shops doing work for me. I think another important aspect is they do not like being pinned to doing particular work requests because it gives them no wiggle room to charge much more if they so desire. There are many angles used to gain added charges that are often used  today.
It's more about wanting to avoid the awkward conversation when the customer's self-diagnosed repair doesn't fix the problem.
Okay I’m a bit  confused here. I have ordered two electrical parts for this transmission   A GM  governor pressure sensor  and what bd and others call a transducer. My $100 big  service book is calling it a pressure sensor.  I’m seeing it now.  Pressure sensor and transducer are the same.  Only two parts to change out.  Not three. I  was a bit concerned. Thanks want to do it right the first time
Yes I can see both sides and a middle to the issue as well.
Ok late last night I had a couple thoughts go thru my brain on the up and coming transmission repair. Want to bounce it off you guys. After the fluid is drained and the pan down and the  parts replaced can I/ we test the  10 amp fuse in the power distribution center by turning the key on no start to see if it blows before we put the pan back up and add the new fluid . Also  I spent $250 on the two quality parts should I use the two new old school parts I have in my emergency jockey box as test dummies.  I would hate to compromise my new expensive parts to test a fuse. Then replace with the good ones. What do you think ?
When you have the pan off disconnect all the solenoids and transducer, turn key on.  If the fuse blows before any component is plugged in then there is a wire shorted to ground.   Now plug the old components back in one at a time and be sure their bodies are grounded.  When the fuse blows you'll know which component is bad.
Power to pin 30 of the transmission control relay comes from fuse I (20 amp) in the PDC
Edited by IBMobile
