- Replies 26
- Views 6.9k
Krlspokane12 8 posts
Mopar1973Man 5 posts
Me78569 5 posts
dripley 3 posts
That should be the DDP slogan.
only thing you can do other than swap injectors to something other than DDP is add a few * of timing at cruise state. 1500 rpm do 15* and 2000 do 19. your issue is your injectors + gears
I'm happy with 320 that now I bet is around 300ish, things wear in and settle down. Stock pop is good which is like 310 or whatever but if it can stay there after few thousand miles then 300-310 is go
Okay, I need your guys help with this. I’m trying to fix this daily tune so my EGTs are not so hot cursing down the interstate. Right now, it is hard to keep under 900 while doing 70mph without any hills.( running in level 3,4,5, changing levels does not really change the EGTs) The truck still has the damn DDP injectors in it since I have not had time to change the tips yet (next on list when I have time) so I know those are part of the problem. Also, the truck does have 35x12.5 with 3.55 gears, so I don’t know if that is part of it as well. Below is what I’m currently running, and any input would be much appreciated.
Power levels: 7
RPM limit: 3400
Max valet mode power: 50
Pump stretch: 1400
TPS pump max: 100
TPS pump min: 20
Min pump tap fueling: 0
Pump low boost scale PSI: 12
Boost scaling: 40
Load timing: 1
Low PSI timing reduct: 5
Timing reduct scaling: 50
Light throttle timing ADV: 2
Light throttle timing load limit:40
RPM timing max:
1500-13
2000-17
2500-22
3000-27
Max:28
CanBus fuel
0-85
1-87
2-90
3-95
4-97
5-99
6-100
7-100
8-100
9-100
10-100
11-100
12-104
13-108
14-112
15-116
16-120
18-124
20-128
22-132
24-136
26-140
28-144
30-148
