Hey all, been quite a while since I been on, had alot going on. Stepped out of the Military-may go back in?, moved into a new house, jobs, kids etc you know. Had the truck LITERALLY completely torn apart: re-sealed engine minus head, completely rebuilt the NV5600 and transfercase, new clutch - which is making some very strange noises, sound deadened the whole cab, re-sealed the hvac box top to bottom, new heater core, evaporator, drier, headliner, wheels and tires; I mean the works! Ill have to maybe make a post with all the pictures? I don't know how to add that many pics though. If youd like to see it all give me a shout and how to do it and ill throw it up.
Any how, down to the good stuff. I have multiple topics id like some discussion over/ questions answered. They are all non-powertrain related so I feel it appropriate to group them here, if not Ill gladly make separate topics to keep everything organized.
I guess Ill start with the dash. I have been looking, reading and researching the DASH. Came across alot of topics here including @Dieselfuture post Time for a new Dash. I think I have decided on going with LMC dash cause I really don't wanna mess with painting it and trying to get it to match :pray: I have spent alot of time already with my dash out fiber glassing  the top and bottom in hopes of making a custom dash top (see pic) and I don't wanna mess with it no more, I'd be cheaper off to just buy one. In that same realm Ill be purchasing a new dash bezel from Geno's  for 87$ - no brainer.
Next on the list is sway bar stuff. I have a 34mm front and a 24mm rear sway bar. They have been off for years, I don't do that much offroading in this rig and I hate the body roll- sometimes. So I'm gonna re-build them and put them back on. With that I am thinking of using Geno's to get the Energy Suspension bushings - still waiting to see if they can get the rear ones, and also front and rear end links from them. Need to see if I can even find the bushing retainers to bolt on from when I took them off...... Thoughts on this?
Lights! These things suck! I have read the article on here for the sport light conversion with projectors. More than likely Ill go that route - with the detailed instructions. Where is the best place to get those lights at now a days? Any further improvements or light availability come about? I found Anzo Lights from CPP Diesel that look pretty decent, but I'm after quality and some bright a$$ lights so I can see. So I need opinions.
Second light topic is cab lights. I have (smoked colored) my original ones long time ago cause that was hip:think:, and had led's in them, now I'd like to get something updated and nicer looking, even if its new OEM style ones. Been looking at Recon cab lights... Any thoughts or users of those?
Mirrors! going to replace my stiff broken tow-mirrors with something like  Spyder X-tune Mirrors from CPP Diesel that are powered and heated. Any other preference?
Lastly I will probably need to replace my steering gear box. I have everything replaced with DOR parts, great stuff, minus the track bar. I have slop left to right while driving straight down the hwy, it gets really bad wander (hard to keep center) when I try to (quickly) change lanes or go over some (whoops) down a back road. Like I have to correct my correction :lol:. So after alot of reading I have found that Blue Top is the more gooder:lmao: way to go. However they are back-ordered now but who isn't... Thoughts on RED vs BLUE?
Ill probably make a separate topic on this one but my wiper delay and power locks dont work anymore.:cry: Through my research it leads to the CTM, to which I have no experience with...
I think that is all I got for now lol. Quite a bit to swallow in one bite but there it is... Again I have done so much to this puppy and have lots of pics I could show it off or if anyone is curious on something or just nosy I'd be happy to share if I knew how to do it.
I greatly appreciate any feed back, comments, suggestions you would have for me. Thank you for reading through all that!
  • Replies 115
  • Views 12.6k
  • Well I guess a little update here:    To piggy back on the CPP ordeal, I received my package (2 of 3) item Friday at 1530 right as I was leaving the shop. After all that with no means of rea
  • Silverwolf2691
    Silverwolf2691
    Most of the time when I hear about lope-ing (loping?) it sounds like the video or slightly more pronounced, more akin to a cammed small block or big block. Usually when you dig through the comments on
  • -sigh- all right, I'll add it to the list, I guess...   It's a Cummins... how would you ever know if there are rattles in the dash?
I think I can agree on the quad from what I've read. I just would like to maybe get some insight on whats going on with my fueling and or timing currently, maybe give me clues on what I got going on in there since I have the world's of unknown going on lol.
All that part with your fueling mods above my pay grade. I do believe I would have bought the Quad before the Comp had it been available when I bought the Comp
I'm totally down to get one! I just need to be smart and find out if I have a problem in any fuel component first just in case I have to replace said item(s).
For all I know it could just be lean on fuel or timing or pop pressures... finding those out would make me a happy camper. I want to use my AC...😁
I'm also having grey smoke 🚬 too. Not black like it should be :burnout:
I'm gonna see about hooking up the Cummins Insight tomorrow and see what I can monitor. If I get something good I'll post it up.
Still haven't been able to use the cummins I sight yet, probably will have to source some connections though, not sure what all cables we have...
I'm kinda surprised that not many people chimed in on my videos...
Grey smoke not completely black and popping has me concerned.
I have read some have clocked the vp44 off one tooth, I have very good faith did not do that but then again no one is perfect... I'd lay money on it though🤣
Might need a bore scope to check gears in the case...
I just had to do injector warranty for my buddy down the road. I sold him 140 HP injectors for his 94 12V Cummins. After he got back from the California trip he blew a head gasket come to find out he had white to grey smoke as well. 2 injectors had issues one he managed to crack the nozzle and the other was was popping strangely sometime popping correct and others no. We upgraded from reman'ed bodies to fully new bodies and DAP replaced all the needles and nozzles and re-popped. Back to running good.
As in popping noise or pop pressures?
The thing is it could be any fuel component? I don't wanna buy another vp44 especially a dragon flow. I could have it tested at Northeast Diesel but the down time......
My boss thinks the advance spring in vpp44 could be weak and cause the surge or "lope"...
I have that black to grayish smoke - no white. And that raspy popping sound in the video.
I thought about pulling injectors (6×18) and having my friend at Northeast Diesel check them out. Again the down time but alot less than vp44 testing.
Dont know what to do and I'm really confused on the lope and grey smoke. Especially since I'm dealing with bigger (go fast) parts. Different than all the stuff I do at John Deere 🤪
Well good news that's bad news. I got to doing ALOT of research and was finding info on people putting keyway in backwards. I have no idea how that would affect timing but.....
All the keyway stuff I've ever messed with personally and at John Deere position didn't matter.
So I stayed late at work got down to the keyway and borrowed my buddies bore scope. Sure as **** mine is in backwards, arrow out towards cover. So I am seriously hoping this clears everything up that I been dealing with. Gonna swap the key around tomorrow or this weekend. Gonna get an extra key just in case (044)...
Can someone school me on how this positioning affects timing?
Also now that I know ideally don't want to drive it like this but I prolly will have too, think I'll be ok???
@Mopar1973Man
Sounds like my issue.... ^^
Then I found this.... kinda my situation to an extent.
I think the key helps set the static timing.
From here: https://www.cumminsforum.com/threads/vp44-woodruff-key-identification.365023/ post 11 says that a degree is an adjustment  of .0087 in a 1 inch shaft.
Depending on how fine they are trying to get a vp44, you might not even be able to feel a difference. (your hair is about .003-.004 thick) But I cant imagine a degree being enough to throw the timing off enough to throw white smoke. Unless the computer is getting way out of whack trying to put the timing in the correct position based on what info its getting, either timing or fueling or something..
My thoughts on it, don't know how right it is. :shrug:
This is why the pumps are place on a calibration test stand. It to find the proper timing and tell the rebuilder what key to use. The VP44 will attempt to reach the set timing amount by either advancing or retarding.
Well I pulled vp44 out and put new key in same number and facing correct way!
Driving back home from the shop it didn't change the white/grey smoke any... still has that raspy popping from exhaust, could be tip or timing again or something else idk. So same stuff different day...
For some weird reason it seems to maybe run "smoother" but it could be my brain trying to make my problem seem a little less worse...
So I'm at a loss again... I had such high hopes of this fix ☹
Help me(sad voice)!:surrender:
Edited by Stanley
Have you tried cracking loose the injection lines one at a time? Is it one cylinder or all of them causing the smoke.
I mean I have bled 1,3 & 4 like I have always done after any fuel repairs, starts up and run good. Drove home today after the key redo. Has power and will "get up and go" but not like it used to. It's not a turd*or gutless to an extent* but not as it should be doing for what it is...
I barely get black smoke mostly grey/white.
*what's hard to figure out is that this is a (was told) dragon flow vp and 6x18 Injectors* (no 100% verification-other than how it acts and drives)=lots of fuel and smoke.
So it's hard to decifer that.
I thought about measuring temps at each exhaust port and comparing?
I found a P0234 code for overboost idk if it's active or stored or how old?- used the key flip -a- roo.
For reference, I can peg a 60psi boost gauge...
I however have the waste gate set at 40 psi I forget why I did it when I done the big teardown :think:
Also note worthy if no one knew, there is no fueling/timing box period just pump and injectors.
So am I missing/overlooking anything?
I'm stumped right now and don't wanna chunk money at it till it's narrowed down.
Here is the pump info, took pic today. Idk who built this? Any insight on who it could be. 028DF is not listed on it...20210825_164617.jpg.7a5c63b2f65dcd11197d4fe308d982f1.jpg
Well went and deleted codes today. This is my p0234 code with values then me messing around with the live data stuff.
Map pressure didn't change however no load...
Think about throwing a map sensor in it and a iat sensor also. Cause idk what else to do...
Gonna also run an over head this weekend just to check. I'll have to order the sensors though...
After that or sooner I'm gonna pull injectors and have them popped and checked over.
Edit:
I forgot to ask about grid heater and all encompassed with it. Nothing is connected its just removed/gone. I'll take a picture if needed. I have both grid heater codes going on, I think p0380 and p0382? Is this of any concern?
20210827_160316.jpg.786953e2a52f010c52dc55857e707934.jpg20210827_160256.jpg.a12da56f6fd008e16e3206b406b1fe0f.jpg20210827_161029.jpg.fd239ef103754f5f2038e43ce5be6f65.jpg20210827_161113.jpg.32ed1189d0a754732a509d317e7ff633.jpg20210827_161138.jpg.203c6bef1417c5f2d8addf1e8e49ad5f.jpg
Edited by Stanley
At 800RPM, 0mph live data shows MAP being 14.28PSI    59inhg-29.92inhg  = 14.28psi
        2.036inhg/1psi
It should be closer to 30inhg or 0psi.   looks like the MAP sensor is reading high.
 At 75inhg boost is 22.1psi
Yup, MAP sensor will be ordered shortly. Gonna go ahead and get a IAT sensor too.
22 psi - Heck, should have been higher 30-40 ish lol.
Think the new MAP sensor would affect any of the stuff I got going on? Timing etc?
I think Mike once told me the MAP sensor maxes out at that 22ish PSIG.
If it maxes out at 22 psi then this would still be way outta wack at idle. I'm thinking there's no other choice on getting one at this point. Grid heaters kinda worry me the more I think about it lol being just not there and unplugged
