- Replies 17
- Views 3.4k
Stubilly 8 posts
Mopar1973Man 4 posts
dripley 1 post
Dieselfuture 1 post
Vacuum pump pulls a solid 26" and the system holds it after shut down. I was pleasantly surprised on that one. Thx Dieselfuture
I would say gauges, as that VP will need steady fuel. Check your turbo for play(fore/aft) in the drive wheel. Coolant likely needs a swap while you are at it, and summer is here. In my experience, dri
I did check the turbo shaft for front to back play when I installed my BHAF about 3 weeks ago-- good and tight with no play axial or radial that I could tell! Coolant change will prob be h
Replaced my injectors with DAP 7 X 0.009 VCO's. Old OEM injectors were down to 3300 PSI pop at best with 242k miles on them!!
Couldn't get the truck to start after that, had a big puddle of fuel under from bleeding!
Installed a DAP VP 44 with NEW electronics and 5 key bumps and 3 long cranks later it started and ran the remaining air out of the system like it should have!!
Original VP couldn't pop 305 Bar on the new sticks. It was really tired after 242k miles (assuming it was the original) I am not the 1st nor the 3rd owner of this truck I am sure.
Plan is to now do an APPS reset and the W-T mod this weekend if time allows.
Still has stock remainder of motor and it needs a overhaul but that has to wait for funding!
I know gauges need to be done ASAP
Is there anything else I should think about???
