Need help with tune or injectors
- Replies 13
- Views 3k
Silverwolf2691 5 posts
Mopar1973Man 3 posts
Me78569 2 posts
Threadzy 1 post
Make a boost test cap. I can hook an air hose to it and turn up the pressure on the regulator and then listen for air leaks. You can mix up some soap water and spray all the air system.
You can cut a block of wood to put between the alternator and your test coupling that will hold on. Mine is the same and blows off with out it.
Morning all,
I've been having some issues with my daily tune for my Quadzilla. I have +50hp injectors that are 4 yrs/20k miles old and have had the Quad for about 2 years now. I can't seem to tune out the smoke In the 0-5 psi area on tip in acceleration. Cruising is clean and at 0-3 psi but anytime I'm hitting a small hill or pulling out onto a road and getting onto it there's a decent haze its not a black out but its enough to be confused/concerned about. It doesn't seem to clean up until 15ish psi. I don't know if pop pressure would be low or if my injectors are a bad set. Also I could have sworn I saw @dieselautopower mention that they updated their injectors to be cleaner semi-recently. Understand that I'm not looking for free replacement or anything, I got them in 2017, mine are out of warranty as far as I know. I am just looking for info right now.
I have been running a 90% start to the fuel table, plus 1 each PSI until 10 then 100% flat from 10-15 then +2 from 15-20 psi, then plus +4 from 22-30+. (previous to noon today)
Maybe I have my timing messed up?
At lunch I'm gonna try the tune below.
Daily
Power Levels: 6
RPM Limit: 3200
Max Valet Mode Power: 70%
Max Fuel Stretch: 1200 us
TPS Pump Max: 100%
TPS Pump Min: 0%
Minimum Pump Tap: 0%
Pump Low Boost Scale PSI: 20 PSI
Boost Scaling: 40 PSI
Max Load Timing Offset: 1°
Low PSI Timing Reduct: 5°
Timing Reduct Scaling: 50%
Light Throttle Timing Adv: 6°
Light Throttle Load Limit: 24%
RPM Timing Max:
1500: 14
2000: 18.5
2500: 23
3000: 27.5
Max: 30
Canbus fueling:
0 - 15 PSI: 85-100% (+1)
16-20 PSI: 102-108% (+2)
22-30+ PSI: 112-128% (+4)
