Dash Indicator Light Replacement
- Replies 25
- Views 4.3k
Leaky88 8 posts
dripley 5 posts
Mopar1973Man 4 posts
Silverwolf2691 3 posts
My cruise light is on the IC and green as well. I replaced my IC lights with white 200 degree LED's and it turned out a sweet Blue believe it! I will snap some pics tonight and
I've seen manufactures use parts from the previous year to use up those parts then change to new style. The fuse is there to protect the wire between the load and power source. Since th
By my calculations, 17 Bulbs total are needed. 7-194’s, 10-74’s. If I go with SuperBrightLed, and change everything to LED, total damage is $66.57. Hopefully the soothing glow of these L
“CRUISE” Indicator light in dash is defective.
Manual indicates it’s a PC74 Bulb.
However, if I’m going in to replace 1, I’d like to swap all to LED, if that’s possible, since all my other lights are LED.
I thought I’d read discussion on doing this, but searches revealed nothing.
Thanks
