Dead truck
Well after all the nice things I have done for my truck it died today. It has cut off on me maybe 6 times at idle over the past 3 weeks but always started right back and kept going. I gues she paying me back for ignoring her. My scan gauge said there were no codes. I did the key trick and got a P 1694 code. I hooked up a snap on solust to her and it read no codes. Thanks to @Haggar for that and I am going to bring back to you. I tried to connect with the PCM and it wont connect, then the ecm with the same results. Checked the codes again and nothing, no connection. Even reconnected the scan gauge and now it will not connect.
I ruled out the lift pump by hot wiring it because the ECM was not turning it on.. I also have no WTS. I wont start she just turns over. I left the key on for quite a while and never saw the WTS illuminate nor would it start.
I guess the truck is brain dead. Hope its not both of them. What do ya'll think?
  • Replies 31
  • Views 5.8k
  • I found a car for dripley and you can be incognito in it. He's selling it for chicken feed.
  • Wouldn't that be something to show up with at the jobsite.
  • Just a little update. Work has kept from digging in much but other than Monday she running glitch free for now.
I don't have any grounds directly under the battery, mine are towards the front bottom and up higher also front, pretty much above the bottom ones.
I did find two on the back of the headlight bucket up high. I did not notice one down low but seem to remember one . I was doing this while dodging random thunder storms today. That did not help much. Have look better tomorrow. I still dont think this is an ECM problem. Sure hope so anyway. I dont want to go down that rabbit hole again.
I drove to work this morning. Fired her off and went to grab a couple things out of the wife's car. While doing that the truck shut off. Fired right back off. Forgot to check the WTS, just hit the starter. No codes were set. So I took off. I the first 4 miles it cut out for a split second but kept on going since I was moving. Stopped for coffee and decided to go for it. It did not miss a lick the 60 miles to work. Checked for codes and none were present. Whatever it is, its still there.
Glad you made it. It tells me there is a small Gremlin still in there that you never chased out. I hope you make it home too Dave. Let her idle in the driveway and wiggle some wires around see if it makes a difference. Remember to stay away from the fan and belt Bud. It was real good talking with you the other day.:thumb1:
Same here Mike. Its funny that idled it for hours the latter part of the week and took 2 trips with no issues. Then this am it glitched in less than 30 seconds. Only difference is it rained on and off yesterday thru last night. Maybe something is getting wet that should not. I will keep digging.
20 hours ago, dripley said:
You better clean that up Dave, you might get kicked out of the club for that .:lol:
Hey you know there is a ground hiding down low under a section of wire harness in front of the drivers battery. Hard to spot until you move the wires a bit.
Idled at work today on and off. drove home and even stopped by another CFA to fix a door closer.. did not miss a lick again.
Little secret all main computer ground (factory wiring) are in the passenger side terminal. Now all the other stuff like ABS, lights, etc are grounded to the body either near the headlight on the driver side. I've seen a few near the fender too. Check out the ground map on the 99 Dodge map will give clues to where your grounds might be.
  • 3 weeks later...
Well the glitch stppped last Monday a week ago. Shut down me 4 times that Monday. No WTS light, no start. The first 3 times I ran the cluster check and bam had the WTS back and she started. The 4th time I ran the cluster check 4 times with no return of the WTS. I had my spare cluster in the back seat and figured I might as well stick it and see what happened. Plugged it in and the WTS was there. Drove 40+ miles home trouble free. I did drive the wifes to work the rest the though.
 Drove it Saturday on quick trip and sure she shut down a quqrter mile from the house anf the cluster check did not work. I then uplugged the cluster and plugged it back in and bam the WTS was back on. Fired her off she was fine for the rest of the trip, about 4 miles.
 Has anyone ever pulled the connectors apart in the dash? There is what appear to be red release tabs for that purpose. I have pulled on them but dont want to rip them apart. It appears that a couple of the sockets appear to be pushed back further than all the rest.
Still scratchin my head over this.
So on my truck, I replaced the under hood 20 amp # 3 fuse. I also checked the in dash #9 and #11 fuse. The #9 will kill the truck if it’s running and no wait to start light will come on if it’s out.
