Replacing head gasket
Ok this is my first time posting here so if I'm missing something please let me know.
I'm relatively new to the diesel world but have read multiple posts on here as well as other sites about replacing a head gasket.
My first question is do you need to resurface the block in addition to the head when doing a hg replacement on these 24v cummins? Also Is it common for the head to be cracked at 200k
This is my dd and I noticed that I am leaking oil right where the head and block meet. I cleaned it up and drove it some more and it definitely looks like it is leaking from the head gasket.
I would need to replace it during a weekend and want to make sure I will not have any surprises that I am not aware of.
I've looked at getting a new head with rings but I don't know what all I would need to do in addition to just a hg replacement.
Engine is from a 2002 2500, has S363/68/12 with 7x.010 Injectors and a quadzilla adrenaline.
  • Replies 123
  • Views 24k
    Correct. You must place the head then install the studs. The longer studs go on the exhaust side of the head. There is one that won't fit between the cowl and the head. I use a floor jack and lift the
  • Dieselfuture
    Dieselfuture
    What he said ^^^   I used a shop vac when scraping the gasket off, that way everything was sucked up as soon as it was lose, it's a but of paint in the but to have a scraper in one hand and
  • Silverwolf2691
    Silverwolf2691
    Not entirely sure on the o-ringing. I don't know if its a static diameter or if the o-ring diameter is based on the cylinder bore diameter, I don't think it is based on just sending the head out to pl
@Mopar1973Man so that was one thing that I was wondering. I had read that the battery's need to be fully charged and the starter running full speed. The only thing that would puzzle me is why would it start with ether then?
Be aware if you lose 1 brush in the starter it will still turn over and start on a primed system. Now try to reprime a system with the same starter is pretty tough. Just one brush will drop the starter to 50% power. Not as fast of a spin. Been here done that.
  • 6 months later...
I know it has been quite awhile but I finally got back out to my truck to take another look. I've been saving dreading the worst (complete rebuild) I brought 2 new batteries and it finally turned over and started but you could tell it was not firing on all 6. It sounded like an old Kubota. I double checked that all 6 fuel lines where getting fuel and then after that did not change anything I ran a compression test on all 6 cylinders and got 450psi or pretty close for all 6. So now I am almost sure that there is something wrong with my fuel side of things.
If anyone has any tips I'd greatly appreciate it.
I was thinking of just getting another set of injectors since that is the next cheapest thing to replace.
How many miles on the injectors? If there is more than 100k it time to replace the injectors. It could be pop pressure is low and the injector is spraying good causing a random mis or just weak hit.
I don't know the exact mileage but I do know they are only about a year old. The only reason for thinking injectors is that they got put in a bag with other parts and it had a bunch of oil in it. I don't know if that could have clogged them or messed them up even more.
Also it's pretty evident that there is cylinders not firing. I looked up videos on 2nd gens in 3 cylinder mode for warming up and it sounds very similar but my truck is shaking quite a bit.
I'm going to triple check the timing when I am out next just I'm case I missed something.
My question for you @Mopar1973Man is with a compression test could it still be bad cylinders even though the compression test gave 450psi?
I didnt do a leak down test as I didnt have the equipment for it. But i would think that if I'm getting 450 on all cylinders they should be fine.
450 PSI is good. Might check valve lash but even with your numbers sounds good.
I would have them replaced if the injectors are plugged up or damage. You could pull the injectors and have them pop tested at a local injector shop.
How long did you run the engine? Sometimes it takes a couple of minutes to remove the remaining air from the rest of the injector lines while it is running.
Before I would pull any injectors or perform any time consuming work, I would remove the valve cover and start the engine.  Don't worry, it will not make a mess.  I would then observe every intake valve and every exhaust valve for full travel of operation.  If any valve is not opening or only partially opening then you have narrowed down the problem.
If everything is normal in the valve train, then I would crack each injector line individually while the engine is idling.  If the engine rpm does not drop when an injector line is cracked, then that cylinder is not performing its share of the work.  Test all six cylinders in this manner.  Note which cylinders are not performing.  This will not tell you exactly what the problem is, but it will tell you which cylinders are affected.  This will save you some troubleshooting time and narrow down the cause of the problem.
Sometimes the art of troubleshooting is not picking something that could be the problem and jumping into it, but instead, it is to methodically eliminate potential sources of the problem that are easy to perform with results that are conclusive.
- John
Edited by Tractorman
@Tractorman Thank you! I saw in another post someone said to crack while running to see the difference or use a laser thermometer to tell which cylinders are not working.
It is a new head that I put on it so it very well could be something wrong with it that I assumed would be working just fine.
Is there a good way to tell if the vales are traveling correctly?
I will go ahead and look this up as well.
After a quick look online I basically just need to make sure they are moving up and down for the most part.
One post said that they received a new head with the exhaust and intake valve that were not in the right spot? But from what I could see on the 2002 cummins it is only a difference of .3mm between the two valves. Should I be worried at all about this?
The answer to your question is yes, injectors should be stored clean, I'm guessing the oil is just oil off of the injectors and other parts so not even new clean oil
As has been said find out 100% which cylinder/cylinders are misfiring either by cracking injector lines one at a time while running and see the change in rpm, cracking a line to a good injector will either lower rpm significantly or stop the motor, a bad one will have little or no effect, or use a heat gun to test exhaust port temps.
If any are bad pull the lot and at worst have them tested by a good fuel shop or replace.
Any injectors I change I always keep the plastic caps that come on the tips and inlets and reuse if needed once spotlessly clean, I also have a large Cat box of plastic plugs and caps which I use all the time
My guess is dirty old oil has got into injector inlets, or possibly a tip, that is more than enough contaminants to cause a misfire
Back to what I was say have the injectors pulled and pop tested and see.
I did an article a while back on how to clean them. The bad part is not being able to measure pop pressure.
Thank you all so much! I was going to try and get to it this weekend but they have me working again. I will update as soon as I can.
Could it be the crossover tube on a cylinder or two are cockeyed? In Mike's article there is a specific procedure given for tightening tubes and injectors.
I'm no expert in this, it's just a thought.
It could be but it would need to be some leak to cause it to run like a Kubota as Tex-usa says and would be adding fuel to engine oil
Looking at the injector shape where the crossovers sit it is also not possible to get them so badly aligned that the injector inlet is blocked off but that's not to say tubes aren't blocked or were contaminated and blocked an injector
Finding out which if any are not firing then inspect/test  injector/injectors and then go from there will find the problem
Basically the cross over tube needs tightening first so the injector can move to self align. Then you can tighten the injector hold down to 89 in-lbs.
Matter of fact is just replaced my injector body o-rings because after the head was service last the o-rings where bit small and injectors fell into place. This was possibly the loss of prime issue. Find out this morning when I start it up. Only took an hour to do this.
:doh: I gotta go back and fix this. I tighten the hold down first.
Ok back at it again after a long month of changing jobs again  :doh:
I started it back up and it would run but still sounded like it was only using 2 cylinders (I went and looked up some that were running in 3 cylinder high idle and it was more choppy then those)
I started with cylinder #1 and losend the fuel line and it shut off right away.
After that I did the same thing with cylinder #3 and #4.
#3 the truck would die but #4 nothing changed.
I did note that even when loosening #4 there was fuel coming out when I got it lose enough but it didn't seem to be spraying as hard as I would have imagined. (If you have a video or know one so I could compare let me know)
After that I tried swapping injector #1 with injector #4 to see if I could see a heat difference in the exhaust but the truck would never start so swapped them back and was able to get it running again but sounding like it was just 2 cylinders working.
When I had it running I did check the exhaust manifold and the first 3 were getting warm but the last 3 were still cold.
I don't know if any of yall have seen this before but I figured I would post what I found.
I'm thinking about getting a set of injectors just to rule it out as they are not as expensive as they used to be.
My other thought is that the injection pump is failing.
If you have any thoughts let me know! I appreciate all the advice you have been throwing at me!
All of that said I did get a video of it running but I'm pretty sure it would be to big to upload so I am looking at how to do that.
I think this may be the best way to share the video.
Sorry if the quality is bad I only really wanted the sound.
 You mention the rear cylinders if the engine were cold. I couldn't help but notice when I did my injectors that the 3 line closest to the block on the vp44 were the 3 rear cylinders.
 For the vp44 exberts here, could the vp44 have failed in a way to only supply pressure to essentially one side on the output lines on the high pressure side?
 He may be getting fuel at all lines but not enough to overcome pop pressure to fire the injectors.
