Oil drip on Driver's side (problem?)
- Replies 9
- Views 2.3k
Silverwolf2691 2 posts
JAG1 1 post
Royal Squire 1 post
LorenS 1 post
Popular Days
Only 3-5? I'm envious!
For me, hardest part was getting the vacuum pump off*. The rebuild was relatively simple. Only other sticking point was once together my pump wouldn't move by hand. Essentially you have to pull on the
I've got vacuum pump kits on the store. Easy to do and maybe an hour of work. Even got a article on how to do it.
Hey everyone,
I bought my first diesel about a year ago and have been learning a ton through you all here. Thanks so much for this forum!
From my research, it seems common for the 5.9's to 'mark their territory' with a little drop of oil. After driving the truck and then parking it, it seems to leave 3-5 drops of oil. I shared a picture underneath the truck where the drops seem to be coming from, but honestly couldn't figure out what this part is. I read the FSM and think maybe it's my VP44?
Any advice on if a few drops of oil is normal, should I fix this asap, or not worry about it?
thanks!
Jared
