- Replies 16
- Views 2k
Mopar1973Man 4 posts
wil440 3 posts
Doubletrouble 3 posts
MikeH 2 posts
It had a dowel pin alright but it didn't look like it had moved at all. I was around the 150k mile mark so I was going in after the crank seal anyway. I'm hoping the rear seal holds up until the clutc
I'm sure that truck was very abused and disposable to whom ever used it. Hopefully you got it all worked out. I may just replace the water pump to since I'll have the cooling system open alread
The upgraded case they had to add quite a bit of metal around the hole. The old case was a suppose to prevent that but with vibration it eats the aluminum case and then continues to walk through. Henc
I may or may not have asked about this before. I searched but didn't find anything so here we go.
My truck is a 2001 3500. Is this KDP I've read about an issue or was it resolved before my truck was built? I have a mechanic at work (trucking comoany) that says I need to tear into the front of the engine and put a tab washer on the bolt closest to this pin to stop it from backing out. I have read about it quite a bit and got no definitive answer as to whether or not they fixed the issue by '01 model year.
Any input? Thanks all!
Also, sorry if this has been discussed before, maybe I don't know how to use the search correctly.
