- Replies 19
- Views 2k
Mopar1973Man 5 posts
gerlbaum 3 posts
McDaniel24v 3 posts
IBMobile 2 posts
The update on mine: I’ve sent the ECM in for a rebuild. I’ve hunted down everything I can and it did it again yesterday. It started, ran for ~10s then shut off. When it does that it sucks all the fue
@McDaniel24vI have to fully agree with Dan @IBMobile in his suggestion to start fresh with this lift-pump relay harness. It's really not hard, the basic aspect is you're using the original control wir
With me working for Caterpillar and the UK cat dealer Finning in the past I only use Deutsch connectors with the gold plated terminals, they are more expensive than the plain steel terminals but make
Hi everyone I hope someone can provide some advice. I have a 1998.5 3500 with a nv4500. It has an aftermarket lift pump, TST Comp, and ts mvp. The current issue has never happened before and I’ve owned the truck since 2017. Over the weekend my radiator sprang a leak. I noticed it when the check engine light came on and temp read ~240. I pulled over and shut it off. While replacing the rad I had two wires where the insulation wore off short. It was the “Cummins bus power” wires (see wiring diagram). I fixed them and the radiator and went to start the truck and no wait to start light and the truck won’t start. I messed around Saturday looking for bad wires, and checking fuses. I go to try and start the truck and low and behold wait to start comes on and it runs fine. This morning I had no issues and drove 50 miles. This evening I went to start the truck again and no wait to start and truck is dead. Went back inside and came out and tried again and wait to start came one and it ran fine for 10 seconds then died. I can’t pull codes because it’s like the ECM has no power.
I am wonder if the ECM fried when the those two wires shorted. Or, could have the hot truck killed the ECM? It appears there is a short somewhere but I can figure out how to test for it or what to narrow down - bad ECM, wiring short, etc…I am hoping someone can help me diagnose where the short could be. I have a multimeter , I can read wiring diagrams and I have the service manual. I don’t know the truck well enough to understand where to begin testing. Is there a ground for the ECM? Is it possible one of the other sensors fried and could cause this condition?
Thank you in advance for any help.
