- Replies 14
- Views 1.7k
Doubletrouble 4 posts
Mopar1973Man 3 posts
Tractorman 3 posts
Alexio Auditore 1 post
I have more questions than answers. Are you the original owner of the truck? Were any of the replacement track bars adjustable? Has anyone ever re-centered the steering wheel during life of the tru
I would at least do a visual check sighting down the side of the truck from the front right corner and then from the front left corner to see if the axle is centered under the truck. If appears to be
Center wheel and be done with it. All good concerns posted by otheres but really doesnt mean anything lifted stock or otherwise. KISS Keep it stupid simple. That
So, I replaced the track bar today. Not a bad job really. But once done I went for a ride and now the steering wheel is turned to the left. The center isn't up and down now but about half way between level and up and down.
I've read that one can fix this by adjusting the drag link that runs from the pitman arm down? Or is this a total alignment issue? I'd rather just fix it here if possible. I don't know why this would have moved anything provided the specs of both old and new bars were the same. (Which obviously isn't the case).
The bar I removed was a moog problem solver. Keep in mind the truck has a bit less than 160k on it. So I assume this would be the 3rd track bar since new. Not a really good record if you ask me.
Thank in advance for any replies.
