- Replies 96
- Views 8.3k
Stanley 38 posts
Silverwolf2691 21 posts
Mopar1973Man 11 posts
YeaImDylan 9 posts
Smoke will come with wire tap trust me lol. Lets get injectors figured out first then go from there
Yes it looks like a standard 028 HO core. We can take it for an 027 SO. Let the sales guy know it is approved and we can get the pump going for you. As @Silverwolf2691 stated
6-700hp is what stocks are generally good for.. possibly more. Hell the factory cam and intake horn have done the same if not more.. not saying its the most efficient, or absolute best pow
First set of new injectors from dap, had to send back for warranty, put 2nd set in then had to do the same thing again. With this being the 3rd set am I just having really bad luck with injectors or is something else causing it?
I keep getting a knock/ping and sounds like a bad miss if u (more prominently)coast and very lightly tap or ride the throttle and just runs rough/ just not how it should. Runs rough and knocks when normal driving the same just more so as stated above.
Why do I keep getting this knock etc? Is the vp44 causing this to go down stream? Fuel psi is consistently 16psi, no codes or check engine light (doesn't mean awhole lot but..)
This has all been in a very very short period of time. The last thing added was the quadzilla adrenaline but I don't see it being any issue?
Only things I can think of is 1- injection pump (runs great) 2- injector lines or tube (mating surfaces looked good) 3- just getting bad injectors.
What the heck?
Edited by Stanley
