Replacing the Cooling System
- Replies 19
- Views 3.7k
pepsi71ocean 5 posts
Mopar1973Man 4 posts
IBMobile 3 posts
Max Tune 2 posts
Is your wife ok with that???
Ya, she pulls one out when she needs a rest.
Mine being a manual I don't have those. Someone with an auto might come along soon and give some input.
Hey guys,
So I'm back to work after a knee injury, and I walked out of Wawa and saw green coolant under the truck.
After some quick diagnosis I determined the radiator is leaking from the crimp joint on the driver's side.
I know a new radiator is in my future, but what about the rest of the Cooling System. I'm talking about the baby hoses on the passenger side that run under the turbo charger, the heat exchanger etc.
I'm not 100% sure how far I want to go, but I have a water pump on the shelf, and a new belt. I might as well swap out other stuff that looks like it will be on its way.
When I got the truck the coolant went 10 years between changes, this current truck is about 4 years in the coolant, but I do check and change some of it here and there.
Are the side coolant hoses a Dodge thing, or a Cummins thing? It seems like a bolt on accessory, so I would assume it's a Cummins.
