2001 RAM 2500 Heat Exchanger
- Replies 28
- Views 12.2k
BDK 8 posts
Mopar1973Man 6 posts
pepsi71ocean 4 posts
Silverwolf2691 4 posts
I would say leave the cooler in place just me personally.
Really simple get a Trans Temp gauge ISSPro EV2 and the pick up the relay adon then adjust the trigger point for the relay in temperature say 160-180*F and then set the warning light for 200*F maybe.
Where are you measuring your transmission temperatures, is a good question. I see it says Ohio is where you live. In which case you would be better the keep the exchanger to raise temperatures up to a
Hey guys,
My son has a 2001 Ram 2500 and the two lines (trans. lines) that come off the bottom seep/leak consistently. I had the idea of just removing it altogether but wanted to see what everyone's opinion is. He does not haul anything and just drives it to and from work.
My idea was to just plug the two bottom ports (trans. ports) with NPT fittings and take the line from the front of the transmission to the transmission cooler. The output of the transmission cooler to the rear port on the transmission. Seems to be the easiest route and not having to mess with the coolant lines from the Heat Exchanger. He has new flexible AN lines, but just can't seem to get them to stop leaking (leaks at AN fitting). Would it be a good idea to upgrade to a better transmission cooler other than the stock one (mishimoto or something similar)?
What is everyone's thought on bypassing and also the method I would like to use to bypass?
Thanks,
Bruce
