- Replies 29
- Views 5.4k
Hey @wil440excellent procedure and I too have been using Dyna Beads for 17 years with outstanding results. The company who produce the mini ceramic beads is on the east coast of the US and the composi
Just recently (in March) I installed a Centramatic Wheel balance Kit (for 4 wheels) on my truck. Same idea, just a different product. The photo below gives you an idea of how they are mounted and ho
I think you are right regarding the stick on weights.... pull them off and put the full 8oz in, we're in the middle of summer here so not wet or humid really, they flowed in through the valve no probl
I've had the Toyo tyres on my truck now for about 2 years and within the last 3 months or so I noticed an out of balance wobble starting to get worse there was several speeds where it was worse and the tyres were wearing very odd like the front edge of all threads wearing off.
When I had the tyres fitted the guy told me the rims or tyres were way out of balance and that he had to use a lot of weight to even get close and to be fair the truck was never 100% and had a slight wobble over 60mph that settled out about 65mph.
It was getting worse so I decided to try beads Dyna beads to give them a name, called the company here in the UK that I presume imports them from the USA ( I think) guy was very helpful and honest and he told me maybe they won't fix the balance problem I have because of the amount of weight my rims have on them.
The guy advises me to try 5oz in each through the valve first, an 8oz pack per wheel is recommended for my rim and tyre size but due to already having weights on the rims he said to go low to start.
So each wheel one at a time on the jack, valve core removed and valve at the bottom, the kit came with a small bottle and a tube that fits over the valve stem, the beads are small enough to flow through the valve, all four got 5.1oz actually.
It has made a huge difference and now there is just one patch at 51mph where there is a very slight feeling that it just might wobble a little but this has gone at 54mph.
Going to speak to the guy Colin and see what he thinks as to whether I put the other 2.9oz in each tyre and keep the weights or take the weights off.
I'm about due to rotate anyway so might just see what it's like when I go back to front, the deal with swapping to another corner is you hit the tyre with a hammer as this dislodges the static stick that keeps the beads stuck to the inside of the tyre in the correct area as they need to relearn and stick differently depending on disc/drum weight and balance so the wheel is always dynamically balanced for the corner it's fitted to and if any do not stick when stopped they are in the right place before a wobble speed is reached
